I recently had a problem where my ebrake was sticking and was able to trace the problem to a sticking e-brake release on the passenger rear caliper. After trying to grease/lube it up, it wont seem to move as freely as the drivers side. The only option I have is to replace the caliper as the part isn't replacable.
my question is, Should I replace both calipers? kinda like replacing both brake discs or will replacing only the one side suffice?
I really want to fix this before my e-brake cable gets stuck...
btw i have an 04 mazda3 hatch
