I was curious about how my rear calipers and adjusters work so I took one off my parts car and disassembled it.
First was the adjuster screw under the bolt.
A magnet works great to pull it out.
The adjuster worked to push the piston out all the way then I could remove it.
This is the threaded screw inside the caliper but it's held in by a c-clip that's hard to get at.
There was grease of some sort around the screw... Must be special grease to be mixed with brake fluid ??
I noticed the spring end wasn't in the little hole to hold it on the outer ring... I assume that would prevent it from ratcheting. I don't know if it was working to begin with or if it was me taking it apart that popped it out.
Then I threaded in a bolt and managed to pull out the gears. The big c-clip just popped out.
That's the inside of the brake piston with the cross in it.
This is the bore that the adjuster came out of... You can see the splines of the screw that the adjuster mates with.
This is the pin that the parking brake connects to.
The pin is really sloppy in the bore and you can see how it would mash a gasket in no time and cause it to leak.
I wonder if that pin and bore aren't cleaned up or replaced during a rebuild.
I can't seem to get it out,.. I may have to remove the c-clip and screw to release it.
I don't have a long reach c-clip tool so I sharpened the points of a big needle nose pliers,... We'll see if that works.
