re:help....can anyone go over 100mph...?
Antoίne said:
drive it off a cliff.
be sure to post your results.
You might want to rig up a pitot tube to an [size=-1]air-speed indicator, so you know the results are accurate.
[/size]Also, make sure it's a tall cliff, so you can reach 100 before reaching the ground.
[size=-1]
[/size]
Pretzellogic said:
Depends on the drag.
(I don't know what I'm talking about)
it Shows (hah) (boom07) Just Kidding!
W X 3.14= TV
W= Weight of Object
PIE= 3.144444444
TV= TErminal Velosity
Good try guys
W X 3.14= TV
W= Weight of Object
PIE= 3.144444444
Good try guys
If I remember my physics, air resistance needs to be worked in there somewhere. Your equation assumes a vacuum.
Anywho, drive off a cliff (not you, 'surf; the 100mph guy).
Antoίne said:
Yeah, air resistance is the force that causes terminal velocity in the first place
Lets see if we can calculate his falling velocity if he drove off a cliff. The cliff is 1 mile high.
Go.
Is the car falling wheels first or nose first?
In either case the terminal velocity of a car dropped in any orientation from one mile up is going to be much, much greater than 120mph, which is the speed usually quoted for a falling human in the spread out skydiving position. The car is a lot denser so it's going to have a higher terminal velocity. In any case, top speed while falling in a car isn't really the record I'd want to hold!
i will give anyone 5$ via paypal to whom ever tries it! (thumb)
My P5 did a tiny bit under 120 and id let off, it takes way too long to get there. haha.
I hit 100 yesterday for like 2 seconds...first time...ever...I was passing a semi, on a 3 lane highway w/ no traffic
Did you go back to the future?
