I got a wheel quick release and hub adaptor. I have never changed a wheel out before. Do u need to have any Special tools or any thing change the wheel??
Just strong upper body to pull the old wheel off. Or you can rent (for free) a steering wheel puller. We swapped out a wheel on my friends 626 last weekend and pulled and pulled and it wouldn't budge. Two little taps with the BFH and it popped loose and came right off. Just to be on the safe side though, make sure you disconnect the battery and drain the charge by tapping the brakes a couple times so the air bag doesn't take your face off.
Don't kill any Barry's. Just disconnect your battery real quick. You can pull the cluster and pull that bulb for the airbag too. I did it to mine. I couldn't stand it. haha
Well I think it might be cause of the abs cause when that went on the ebreak light went I to I tryed to ground the ebreak wire and that didn't work so I think is cause of the abs light is on
