rar40941's build thread
Hey man, nice build, i see your persistence & i must say well done, by the way, what is the color of those xxr rims?
On it's way to you, buddy. :)
I got a wheel quick release and hub adaptor. I have never changed a wheel out before. Do u need to have any Special tools or any thing change the wheel??
Just strong upper body to pull the old wheel off. Or you can rent (for free) a steering wheel puller. We swapped out a wheel on my friends 626 last weekend and pulled and pulled and it wouldn't budge. Two little taps with the BFH and it popped loose and came right off. Just to be on the safe side though, make sure you disconnect the battery and drain the charge by tapping the brakes a couple times so the air bag doesn't take your face off. :)
Well my air bag light is already on cause I took out my seats they had side air bags but I will make sure the Battery dies before I try anything
Don't kill any Barry's. Just disconnect your battery real quick. You can pull the cluster and pull that bulb for the airbag too. I did it to mine. I couldn't stand it. haha
Why is your ebrake bulb on? You might as well remove the whole cluster then. haha
I have no idea y the e break light is on but after I installed my AAC rear later kitty went on I can't fix it it's been like that for ever
Ebrake light is more then likely a broken ABS sensor or your parkbrake solenoid needs to be cleaned under the parkbrake handle.
Well I think it might be cause of the abs cause when that went on the ebreak light went I to I tryed to ground the ebreak wire and that didn't work so I think is cause of the abs light is on
Broken sensor will cause both lights every time. Just fix the sensors so you have fully functional brakes and speed sensors.
Similar Threads and Articles
