Just made a quick stop at my local dealer looking for repair wire or other pieces to make my own OEM adapter plug.
If you want to go OEM with the in dash tweeters the part number is KD62-66-960 and cost $16 each.
http://www.mazdapartsunlimited.com/oem-part/mazda/cx-5/2013/grand-touring/2-0l-l4-gas/body-hardware/sound-system/inst-pnl-speaker-right/kd6266960
I may just chop the plugs off these and solder together my own adapters if the OEM speakers sound bad.
are these plug in and good to go?
assuming NolaCX5 got the part # right then yes they will have the female portion of the connector that will connect to the male piece that will be plugged in a plastic piece just under the trim in each dash speaker location.
PS NolaCX5 is wrong about being able to chop off the connector off the stock speaker, its molded into the speaker its not coming off.
I applied 1 layer of FatMat sound deadener to 2 front doors and the cargo area and noticed a little over a 1db reduction in noise. I then applied a 2nd layer to ea front door and 2 layers to the left rear door and noticed a 3db reduction in noise. I ran out of time but my plan is to complete the right rear door and go over the cargo area once more. All tests were done using a iphone app driving 70MPH on the same highway.
if you are asking about the doors, then I covered over the black plastic. On the cargo area I removed everything. I also attempted the rear hatchback but it looks like it will be time consuming. I'm going to look for some sound deadening material I can stuff in the rear hatch in between the outer and inside metal hatch.
Isn't covering the black plastic against what the instructions would say? Did you try to take the black plastic off first or did that turn out to be too much work? I ask because i have two dynamat door kits that I will be applying in a long weekend coming up hopefully, don't want to waste them.
I ended up ordering the two KD62-66-960 speakers and will be receiving them some time this week. I had a leaner touring model from the dealer for a day with the six speak factory unit and it was an impressive (and noticeable) difference between the two. For less than $35, I really can't see a reason not to do it, especially if you have no intention of installing aftermarket speakers or a stereo.
I just want to say thanks to all of those who have done the research to find that part number. That saved me a lot of time and hassle.
Oh, and if you try and order them from onlinemazdaparts.com.... well apparently they are undergoing a "management change" and refusing orders until further notice.
I think without using the oem bracket, just a speaker adapter, your going to be hitting the back of the speaker with the glass.
Have you tried lowering the window in the rear yet?
I dont have an issue with just removing the oem speaker from the bracket, even if it means destroying it. I am very not likely to be uninstalling the Polks later on anyways.
looks like db651 would fit just fine when the oem speaker is removed.
