question about motor mounts
jlocurto
2008.5 Black Mica Mazdaspeed3 Grand Touring 7/15/08
alright so before i buy any motor mounts i was just wondering how hard they actually are to swap out?
do you have ramps or jack/jack stands? Some basic size sockets? and 15 minutes?
Its really quite simple and when you take out the stock mount and compare it to your new one, you will be surprised mazda let the MS3s come to consumers with that bad mount
oh wow thanks! i was talking to someone today and they said that sometimes you need to lift the engine and s*** but i guess not
thanks im definitley getting one asap!
The inserts can be a slight PITA though. I was wishing I had an actual replacement mount when I did it. Had to get the neighbor to help pull the engine forward so I could get the stock mount with inserts back in.
they proly talking about the side mount, the rear mount shouldnt take more than 30 min
I installed the TRZ in about 10 min. Easy install, and great response with the new mount!
is there a difference between the different brands? i mean its just a motor mount..
I think there is big difference between mounts. The TRZ is a complete different design then the other mounts and also the stiffness is a big factor. The TRZ is the only one I've tried since stock but I would never go back. You cant beat it for the price either.
For instance, I have heard that the cp-e mount, although pricey, has stock level vibrations but is incredibly stiff = better traction, etc.
