Titanium-99
- 2007 Diamond Graphite Infiniti G35 Coupe
brealmp3 said:you might have missed it, but i already have the bar and endlinks. i'm just getting ready to do the install, but thanks for the pep talk
My reply was for the guy that started this thread!
So you got the progress rear sway Bar for your msp? if you did you will need to use a socket and a jack to get the bushing brackets on. you will want to put the socket on the jack and then jack up the bracket till you crush it into place but you will want to have started at least one of the bolts on the bracket. if you get it to work the swaybar is going to rub like crazy on the latteral arms coming down from that center plater on the subframe.
so in theroy its not going to work but will at the same time. oh and the stock endlinks will be way to long!
