[Prodigy's Race Protege Project]
^^^Wow! That is quite a days work. Good job!
Well, it was actually a week's worth of work.
I spent an afternoon installing the suspension/sub-frame/tow-bar... a day removing rust and sanding the body for paint... and another day painting.
that is so exciting. im so excited!!! haha :D
(yippy)haha.. My gf said the same thing.
The only thing stopping me from finishing the car in a week is the fact that I do not have any brake components to put on the car. :(
Christopher! Did you get paint on my Miata wheels??
;) Hell, I'm just happy to see that they live on on a race car!
I was planning on getting new tires and repainting them.. no need to waste energy masking them off.
Coming along nicely
Thanks!
Thanks!
what brake setup is on the car? I may be able to source something..
Still subbin to this thread and for good reason...Nice work...Looking forward to updates with plenty of juicy (pics)
At the moment, nothing.
Plans are to have a wilwood dual master cylinder brake/clutch pedal set-up (with a balance bar)
-Wilwood superlite 4-piston calipers
-13" rotors
-4x100 hats
-AWR rear drum to disc conversion
-wilwood calipers, rotors and hats
I don't want to go with OEM MSP calipers due to the fact they overheat way too fast.
any updates on the car?
Not on the race car... but I finally have a transmission to go in the red car (so I can keep the cryo'd gears and Quaife LSD for the race car).
http://www.mazdas247.com/forum/showthread.php?t=123733499
I'll be pulling the boosted 2.0L and trans out of the red car next week if my work schedule is open.
(2thumbs) Thanks!
Just received some tail lights for the race car... since the original tail lights from the parts car were destroyed in the Atlanta tornado awhile back.
Just ordered some .580" Moroso extended wheel studs and a momo mod 07 steering wheel.
At least it'll look like a normal car from the outside soon.
Not to chit-chat in the other topic (transmission), but thats a regular G15M-R without the LSD as far as I can see ?
Also what do you plan on doing clutch-wise ?
Yep. The Quaife is still in the red car.
The 'stock' transmission will be going in the red car while the racing trans will be going in the white race car.
I'm using an exedy stage one full-face until it runs out of life.
After that I'll be going with a custom 6-puck friction disc with the exedy pressure plate.
finally got around to reading this...looking good thus far. I assume your keepign the 4x100 lug pattern for the ease of wheel selection?
I still deciding on that one.
I'm getting a Brembo big brake kit that already has the 5x114.3 hats for the front.
But I already have the cnc machined AWR drum-to-disc brackets for the rear which is 4x100.
I might mix match them to keep my mind at ease.
(I highly doubt anyone would try to steal rims with different lug patterns. lol)
I'm mostly trying to avoid this from happening to the race car.
Race wheels, tires, and Brembo rotors are not cheap!
OK, confused, did you get ripped off, or did you take them off to stop from getting ripped off? I'd hope you'd block the car better than that...
