Problems: Turbo kit& MPI Piggyback
Thats cool!
Little Beavis was here in PR last week and he helped me with the tunning. Car was running so damn great with his tune. Then I found something interesting. We almost blew the engine. Yesterday I discovered that we were injecting on only 2 cylinders!!! (aditonal Injection).
We didnt notice because we were only tunning for 5psi and the stock injectors were shooting most of the fuel and the aditional came on to make a balance.
I did noticed @ day because I was hearing a bit of pinging thru the microphone setup.
This could mean that we had 2 pistons running HOT and now could be a bit bad.
Well...I just hope that they dont find anything wrong with my car that needs major work....or else im into alot of explaining to the wife..(nervous)(rant).....
Jeremy
Igdrasil, that IS interesting... Keep us posted. So you are saying that the stock injectors crapped out?
EDIT: You know now I know what you are talking about. You are referring to the J&S lighting up only 2 cylinders? The same happens to me.
I dont have a J&S but I need one for sure.
I knew that because when I opened the hood, I saw 2 disconected injectors (aditional injector harness).
The engine is still running because the stockies were throwing most of the fuel, but Im sure not enough for those 2 that were not having the extra fuel with the extra injection!
Will do a leak test, dont know when.
Im going to do some normal driving from home to work....
As far as visual inspection, there still no cracked piston so far.
