Power Steering system failure
supermars
mazda5
Hello friends,
My car got an accident yesterday. When I turned to left, another one hit my right side fog lamp. After towing my car to my home, I found the power steering system is failure. I checked the EHPAS 80A fuse, it is OK. No physical damage. Still extremely hard to turn the wheel.
What's the reason for this failure? Before it works well.
I learn that the EHPAS module in power steering pump will record some DTC info.
My question is, is that possible to replace a new pump and everything will be fine? $250
Or should I find dealer to erase this information instead of replacing the pump? More expensive.
Thanks for your suggestion, Experts : )
If you got into accident have the car checked. It should be covered by insurance if you are making a claim.
We had a his at the back side and that jolted car enough to screw up power steering rack but the damage to the car was minimal.
The EHPAS module/pump is located by the washer reservoir on the passenger front. Check or damage to the 2 pin pwr/gnd connector or the 4 or 3 pin communication connector (may have a communication code stored... Code starting with a U). If all is well then is possible the module/pump assembly may have failed. Junk yard parts will work but will need to be programmed to the vehicle for proper performance.
Hope this helps
Power steering failure reasons.
Hello friends,
I had the same problem with my mazda 2. The steering wheel was stiff and really hard to turn. I consulted Apex Specialized Automotive Inc, it is one of the providers mazda service in Edmonton. They told me the steering fluid is leaking and better to change the steering pump. I think you are also facing the same problem. Anyway check the fluid level and also check whether it has any leaks somewhere.
