sasp5 said:anyone have pics of their P5 with stock wheels with 205/50/16 tires pls.
this is more likely a function of the sidewall characteristics of the particular brand of tires you purchased as compared to the stock tires (the difference in sidewall height is just 0.2")ottawaP5 said:I found a big difference in ride quality..I find the 205 50's soak up the bumps and potholes much better.
nate0123 said:this is more likely a function of the sidewall characteristics of the particular brand of tires you purchased as compared to the stock tires (the difference in sidewall height is just 0.2")
bulls***LEXUSLEO said:If you decide to get the OEM size, I would recommend the Michelin Pilot A/S from Tire Rack. They are $150/pc., but they have a 60k treadlife and ride really quiet. I too was going to get 205/50/r16, but was told this would cause premature wear and trear on the suspension and steering, and also if you look at the tires from the side, they seem to buble out a bit. Your choice.
not sure - maybe someone who has had these tires can commentottawaP5 said:How different are the sidewalls of the Falken 512's compared to the stock dunlops?
nate0123 said:bulls***
sasp5 said:I agree
