igdrasil said:8psi hehe
ask Kooldino...how much is he pushing? 14psi? oh wait...how about the MSP that MPNick did? 17psi and now 23psi?
MPNick said:Hello Mr Ghost P5, how are things going?ghostP5 said:This is ghost. I wanted to know how much the MPI is. Im ready to buy an engine system for my turbo, and Im kinda pricing around. Can you please help?
The cost for our MPI Tuner and Turbo module is $795.00. It comes complete with everything you need to install and tune for upto 8 psi.
Please let me now if you have any questions at all.
Thanks agian
LinuxRacr said:Do not piss the Ghost off. you will not like it...nor will I! (eek2)
LOL!!!!!!! Imsorry DooMerDooMer_MP3 said:Well you should've said it included all that s*** for $1000, god dammit!
Chris
$1300 for rods and pistons. Plus $300 for gaskets, then any machine work, etc etc.ghostP5 said:Now If I get internals, add 1300 to the 1000.
Nope, I'm running a MAP sensor as well. Probably the same one you're getting. And yeah, I have 2 480cc extra injectors. You'll still run into the MAF limit like me though. The MAF limit is causing a problem with the stock ECU, NOT the MPI tuner. My MPI tuner does not know that my stock MAF exsists.Then Ill be able to boost as much as Dino, amybe more sisnce I will have 2 extra injectors, and a 3 bar Map sensor to run them. Dino runs his extra with the stock MAF. Now hes at his limit.
Kooldino said:$1300 for rods and pistons. Plus $300 for gaskets, then any machine work, etc etc.
Dinospeed is using the 80mm mass air with his car, that's how he can make the big power. The 8psi is the "safe" point on the stock injectors, you can go higher with additional fuel.ghostP5 said:Now this means ill be able to get 10-12psi for about 1000, ok guys. Nicks unit is 795 for only 8psi.
Now If I get internals, add 1300 to the 1000. Then Ill be able to boost as much as Dino, amybe more sisnce I will have 2 extra injectors, and a 3 bar Map sensor to run them. Dino runs his extra with the stock MAF. Now hes at his limit.
Actually i am runnin 10psi..and boost creep at 11-12psi..But it alwayz falls back down to 10psi.LinuxRacr said:I have no extra injectors, and I am running like 5 PSI right now. Acidbbg is running about 11 PSI right now without extra injectors on the MPI Tuner. Hopefully in a couple of days I will be running 12 PSI!!
what do you mean slow?igdrasil said:it can...but remember, our stock injectors are slow...so, real good tunning is required to run the car smooth
