Pcm replacement
2001 Protege
Will any pcm from a FS work? I noticed the have different 4 character codes. Mine needs replacement and I want to make sure I get the right one
Just be sure you get one for the correct engine and trans and you should be OK. If you have an auto, make sure it's for an auto, if you have the 2.0L FS motor, be sure you get one from an FS 2.0. Be sure you don't get an Mazdaspeed ECU unless you have a turbo on the car or it will not run properly.
