Thanks to pringles, got the left hub off. We couldn't get the axle off though, is there a secret to this or do we just have to keep using pry bars?
You can't get the axle off of the driver's side or the passenger? If you have the half shaft off the hub all you have to do is pull back hard. I just had 3-4 hard tugs on it and it came off. If it's the passenger side then make sure you have the shaft unbolted from the engine. The half shaft is connected to an intermediate shaft (IDK if that's what it's called) so it'll be better to unbolt it there. Besides that it should just pop right off if nothing else is holding it in. Just make sure to use a lot of PB blaster or something similiar.
