Please Help a fellow msp owner out, have a problem i need advice on asap.
threw a check engine light for the p1072 code for rich air fuels bank 1. Now when i accelerate and go past vaccum it's like hitting a brick wall and sputters. Could be the 02 sensor in the exhaust mani but it has been replaced before. vac lines are fine no leaks, egr has been cleaned, could be maf i guess it's been cleaned often but i don't know if it needs to be replaced?? Spark plugs are new, have a 626 coil pack with low miles on it, been running a walboro fuel pump and had no issues for many miles before. Any suggestions as to what could be going on?
By the way I might add that I just got finished with a silvia turbo installment. Peaks at 11 psi. NOT good. used the same atp turbo wastegate set for 6psi that worked fine/didn't overboost with my stock turbo before it went out. Could possibly have it on wrong? or maybe the flap is partially stuck open and is why I am peaking at 10-11 psi. This turbo spools mad quick compared to the stock one, practically at idol regardless. I really don't want to take it to a shop when it could be something minor
