Rumbling sound - getting worse
Our 2019 CX-9 has gotten noisy. We have 128k km (80k miles?). It sounds like one driving over a metal grate bridge - waaaaaahnnn. The faster you go, the louder it gets. The transmission gear has no effect on the sound, even in Neutral (at speed)sound is still there. However: if you nudge the wheel left - just a touch - the sound goes away. So you can wahn, nudge, wahn, nudge to get a bit of relief. TIres are Pirelli Scorpion AS3 Plus with less than 10k km on them, stock size 255/r50-20. All pressures at 34 cold. No sing of premature wear.
Any ideas?
Wheel bearing. Likely the right side since the slight turning motion unloads the bearing briefly. Time to get it replaced for sure if you can hear it that clearly.
