we were discussing baout what would be the best way of doing it
and yes, i saw the bolt on the bottom too and wanted to ad an L shapped fitting and attach the hose there since it would have the best access, thing is that the weight of the water would create pressure and maybe leak from the radiator, tho kinda impossible to do, it may happen.
we decided it was best to try and fit another hose thru the little nipple and have it long enough to reach the bottom
and to keep the hose from being closed by the bottom of the can, i made a diagonal cut to the end of the hose so that it will always suck water in
the design of the car, materials wise, is great...but i dunno in what kind of cars this thing goes that it was designed like that...
another thing i did notice was that there is no difference between the design of the OIL catch can and the COOLANT overflow can
serg has both and they look exactly the same.
have fun
worst 50$ spent on a useless mod....i still bug serg about it
Mark94 said:
I have a Weapon R coolant tank and there is a plugged hole at the bottom. I removed the plug and found a screw in nipple at home depot to take its place. I ran my radiator return line to this and used the nipple up top as the dump tube in case it ever gets too full and needs to release some of the coolant.
Glad you figured it out though and caught it before it did some serious damage.
Mark
