JasonBourne
- 2003 Mazdaspeed Protege
hi, besides the dealer, where i can buy a OEM oil cooler???
stealthwyvern can you help me??? the story: few days ago i check the coolant tank and for my surprise, it had a little spots of oil in that, i check the radiator and it was the same history.... well i took the car to the mechanic and he test the oil system with pressure and he told me that he didn't found any leak, he did a compression test and it was ok.....I was thinking that may be the oil cooler have a little crack inside it, because the other option is the HG, but i don't think that the HG is the problem because i don't see the symptoms of that....
