MSP2003.5_Nick
- 2003.5 Mazdaspeed Protege - Dark Silver
04 Mazda 3 2.3L I got 380,000km on it and have been feeding it oil for a year. Decided to finally dip into it, pulled my plugs and found cylinder 2 was soaked in oil both in the cylinder and around the plug itself where the coil pack boot connects to it. Did a compression test and all cylinders were 180psi with exception to cylinder 2 which had 220. Looking down the spark plug hole I could visibly see the oil pooled on top of the piston.
I started with a valve cover gasket cause I thought it could be leaking on top of the plug but that wasn't it. My question is how do I tell what is bad, valve seals, piston rings or head gasket? Or should I just say **** it and pull the motor for a full rebuild of everything?
Car is my wife's daily so I don't want to have it off the road too long if possible. I already pulled the motor last year to replace rod bearings, should have just done the whole job then but I didn't make the connection that oil consumption was the cause of the rod bearing failure until after. Also I've previously changed the PVC with no changes.
Anyone have this problem?
