S ScottPro5 Member : 2006 Mazda 3 2.0 Mar 29, 2005 #1 Is there a gasket that goes in where the header connects to the midpipe?
Y yourfather_luke Member Mar 29, 2005 #2 yes...it comes off of your original one for re-use. read the how-to...it's well documented. you have to kind of shimmy it off a bit.
N Nutari Member Contributor : 2010 Mazdaspeed3 Mar 29, 2005 #3 the round dounut gasket. order it from mazda..
F Fade Member : Mazda (duh), P5 Mar 29, 2005 #4 Doughnut gasket. Be carefull when trying to remove it. It might be stuck to the stock down pipe.
A ahb11m Member : 99 1.6litre Proteg PT Mar 29, 2005 #6 be careful when removing it... it dflakes away.. and i swear the fibres in it are bad... left a rash on my arm, coz the fibres went airborne...
S ScottPro5 Member : 2006 Mazda 3 2.0 Mar 31, 2005 #7 did anyone get a check engine light after installing it?
M Minishotglass Member : 03.5 mp5 5spd Mar 31, 2005 #8 ScottPro5 said: did anyone get a check engine light after installing it? Click to expand... this will fix your CEL problem http://www.msprotege.com/forum/showthread.php?t=66426&highlight=nonfouler+fix
L Lord_Zath Member Apr 14, 2005 #10 Pics of said donut gasket. #1 before #2 after I think the gasket is lead-based, so use a flathead screwdriver to gently pry it off and avoid skin contact! LZ Z Attachments DSC00618a.webp 62.7 KB · Views: 164 DSC00619a.webp 53.3 KB · Views: 146
V vapors Member May 1, 2005 #11 is this the same for the AWR header? do you have to use the stock size one or do you have to use a different sized one? anybody know?
