Good info here everyone!! Except for all the pointless fighting. I was looking into getting a new brake package, but now I'm reconsidering it. I think I'll just stick with the Hawk pads and SS lines.
Yes, I already did know that the discs are carbon fiber but the point was, which you missed, that the holes in the disc are there for a reason and not just for show. In this case, especially to dissipate heat.AlbinoMuntjac said:SNike05- Yeah, the Mercedes has crossdrilled rotors. It's also a purpose-built racecar that they needed to homoligate. And if you had taken 2 seconds to look even further into it, you would have found out that they have carbon fiber rotors, not steel or aluminum. Carbon fiber isn't metal, so yeah, it will heat up, but it's not going to warp and it's going to take a lot more heat to crack or warp them compared to metal ones. Nice try chief.
Here's my problem...on OEM pads I have warped the rotors on my MSP...TWICE!!! In less than 20k miles! ARGH!!!! Got them replaced before...but I think the wear parts replacement on the warranty is up...now I'm kinda stuck. Nobody makes a less expensive rotor for the MSPs. KVR makes some, but their WICKED freakin expensive...+500$ for a full set front and rear.jared said:I am failing to understand how slotted rotors clean the pad.
Is the rotor raised slightly where it's slotted?
If it's not then it's the same as drilled.
on another note, here is my formula for the best braking for out cars
1.OEM rotors
2.Hawk pads
3.SS brake lines
4.better tires
Do you wash your car when it's warm and spray the rotors? that can warp them.servoeyes said:Here's my problem...on OEM pads I have warped the rotors on my MSP...TWICE!!! In less than 20k miles! ARGH!!!! Got them replaced before...but I think the wear parts replacement on the warranty is up...now I'm kinda stuck. Nobody makes a less expensive rotor for the MSPs. KVR makes some, but their WICKED freakin expensive...+500$ for a full set front and rear.
Also...how do the SS brake lines help and where did you get them?
Listen to this guy he know exactly what he's talking about. And to answer your question about rotors. You can find solid and vented plain rotors by brembo on ebayI've seen them for quite a long time.jared said:I am failing to understand how slotted rotors clean the pad.
1.OEM rotors
2.Hawk pads
3.SS brake lines
4.better tires
But not for the MSP, I think...Brembo doesn't list anything for the MSP, yet. The KVRs are the only ones I've found...and Corksport actually has the best price on them.melicha8 said:Listen to this guy he know exactly what he's talking about. And to answer your question about rotors. You can find solid and vented plain rotors by brembo on ebayI've seen them for quite a long time.
RyanJayG said:no big deal... people just need to chill on this topic... besides on the street (where glazing and brake fade aren't a problem... EVER) even larger brakes will not stop you faster... out tires are the weakest link.
They have the same brake set up as the MP3 and P5servoeyes said:But not for the MSP, I think...Brembo doesn't list anything for the MSP, yet. The KVRs are the only ones I've found...and Corksport actually has the best price on them.
well, that statement was aimed at out 2900lb protege's with stock brakes sizes... not a 4500lb monsterMike R said:Well, not with the protege's. But I melted a few pads on my Crown Vic. The rotors were also blue and had lots of cracks. Brake fade is damn scary.
Its been said on here before but I will repeat... TIRES!!!mrpopnfresh said:Good info here everyone!! Except for all the pointless fighting. I was looking into getting a new brake package, but now I'm reconsidering it. I think I'll just stick with the Hawk pads and SS lines.
servoeyes said:Nope...the rotors have only warped in the winter, when I've got my snows on. My ABS is terrible...seems like hard braking (especially in the winter) will still warp the rotors. When I wash my car, I wash it in the shade.
Just got back from the dealership...had to get rotors resurf'd and the front pads replaced. The pads were actually what caused the warping. The vent in the pad was full of poopoo...no venting at all. So under emergency braking I would up warping the rotor. As for torque...I'm honestly now sure how tight to torque the lugs. I hand tighten them generally, with one hand and the shorty bar that came with the car.CrazyCaker said:Over tightening your lugs will cause your rotors to warp very quickly. When you put your winters on how tight are you making the lugs? Use a torque.
servoeyes said:Just got back from the dealership...had to get rotors resurf'd and the front pads replaced. The pads were actually what caused the warping. The vent in the pad was full of poopoo...no venting at all. So under emergency braking I would up warping the rotor. As for torque...I'm honestly now sure how tight to torque the lugs. I hand tighten them generally, with one hand and the shorty bar that came with the car.
--edit--
any idea if the pads on the MSP are the same as the pads on the other Pros? I'd love to get some hawks of green stuffs or something that's not gonna warp the OEM rotors.
