twilightprotege
- 2001 323 Astina SP20 (P5)
tiwing you are correct.
and reducing the glazing increase pad bite.
jared said:i got pics too...
Corvette C5R = no slots or drilled holes. This car has won LeMans.
On a street car, crossdrilled or slotted rotors will not benifit you.
If you read the whole thread you would see the sales guy was giving an opinion and passing it as fact based on sale information brochures.SciFiMan said:That link is just some guy expressing his opinion on another forum. I didn't notice any scientific comparison testing and data results. That's the trap of the Internet, if it's in text anywhere people take it as gospel and the author as an expert.
Sales BS...p5sundevil said:this thread is some funny ass shiat.
Cross Drilled: Offer an enhanced initial bite (more responsive, especially in wet weather) and greater heat dissipation (reduction in heat induced fade - "brake fade")as compared to O.E.M. With 40% Better Cooling, 20% better stopping, improved wet braking, reduces rotor warpage, and less brake fade.
Gas Slotted: Slotted discs offer cleaning of the friction material (brake pads), but do little in terms of additional heat dissipation. Slotted brake discs do not cool better than cross drilled discs or even standard discs. The face grooves will slice the brake pad material allowing the pad to bite harder into the disc, therefore causing an increase in disc temperatures. This is recommended for competition vehicles to bring pads and disc temperatures up to optimal operating ranges. (Race cars warm-up engines, tires and brakes for the best possible performance).
www.corksport.com
But there is less mass to absorb the heat in the first place, which means more heat is transferred to the pad and other parts of the braking system.twilightprotege said:just with the x-drilled they do cool better...more surface area is open to air.
think of a tube. the area of the cylinder parts is greater than the lids
I thought that they didn't reduce brake fade... wasn't that the point?(fight)RyanJayG said:people... stop arguing... YES, non slotted/drilled rotors will make you stop better (more friction) but this is only for a little while in racing applications. after a few laps the brakes will start to fade if not supercooled and pads cleaned (via slots)
now, that being said... after a lot of hard braking, slotted rotors and cross drilled rotors WILL stop your car better because the reduce BRAKE FADE. but you would truely never encounter brake fade on the street unless your brakes are ******.
are slots/holes important on a street car? NO! but it does look cool.... end of story
*edit* also the stock protege brakes are quite good, and will out perform your tires almost every time.... if you actually want to stop faster, get R compound tires
Stock sized slotted or cross drilled rotor will not out preform stock OEM rotors.RyanJayG said:people... stop arguing... YES, non slotted/drilled rotors will make you stop better (more friction) but this is only for a little while in racing applications. after a few laps the brakes will start to fade if not supercooled and pads cleaned (via slots)
(snip)...
I think you are missreading me... I said NON slotted/drilledStuttersC said:Stock sized slotted or cross drilled rotor will not out preform stock OEM rotors.
The rotor material is not "stickier" on slotted or cross-drilled rotors, how is there more friction?
This where the arguement degraded into name calling in the other thread. there is no empircal evidence proving that cross-drilled/slotted rotors are in fact better than OEM parts.
Oh sorry...yes I did misread you...(hand) (hand)RyanJayG said:I think you are missreading me... I said NON slotted/drilled
