Strange huh....fuses good.....checked all the wires I could get to.....I'm not sure if this car has a ignition solinoid...if so I guess I could change that.....all I need is some gas/air and spark and I know I'm getting two of those....
QUOTE=RaiderMP5]Have you verified that all the fuses are in check, as well as ground connected properly to the frame?
You got power into the coil, you should have spark coming out. Something is not right for sure, but you know that already.[/QUOTE]
