New Exhaust/ Check engine
I ordered my exhaust from Corksport, I know when I install it I am going to get a check engine light... What piece do I need to Bypass this? and where can I get it? Easy to install?
THANKS!!!
if you are removing the catalytic converters you need a MIL elminator from someone like Apex Motorsports or there is a how-to on how to make your own here on this forum
get a spark plug adaptor(18mm IIRC) and run it as an o2 extension. costs $3 at any and all you have to do is drill out the hole to be a bit larger. screw the adaptor into the pipe and then the o2 sensor into the adaptor.
