spoolinmp3 said:And if it is oil than 99% its your turbo oil seals getting to much pressure and this can be easily alleviated by a restricter in the feed line.
Wouldn't a restircter increase oil pressure?
My thinkings are that it would increase the pressure behind the restrictor but lessen the oil pressure going into the turbo.DooMer_MP3 said:
I was thinking the same thing. Don't you increase pressure when you force a fluid from a larger diameter to a smaller diameter?![]()
Chris
"You eat pieces of s*** for breakfast?"1st MP3 in NH said:
You drink sex?....
:wtf:
too much fuel is not that safe. cat converter can become clogged and cause severe backpressure and alot of future problems.igdrasil said:Yeah, My car only do black smoke when pushing WOT.
But now it does the combination of blue and black. which means that Im running rich enough but also burning oil.
You can tell the difference by the smell.
Your case? You are running too rich!
But at least you are safeh
you guys are running vortech fmu's right?
what disc do you have installed? i would recommend the 8:1 for low boost. i know kooldino has the 10:1 and is running ok , but to each there own.
