Little Beavis
- 2001 MP3-T (#911)
Well, here's what I got with my new Greddy EGT (mounted in the downpipe, right outside the turbo outlet).
Cruising 75 mph. 660C / 1220F
Rich, right?
Car also seems to idle a little rough and expell a little blue smoke at idle and a bunch if you hit the gas. (smoke) (notcool)
Fuel is a Vortech FMU 12:1 with an inline pump right before the fuel rail. Is the pump raising the pressure causing the rich condition while cruising and at idle? (I'm still waiting to receive my fuel pressure gauge, so I can check that.)
At WOT, the temperature doesn't really change. Maybe goes to 680C / 1256F.
I'm curious. I have a 10:1 pill for the Vortech. Should I use that? I do notice that the car pulls much better at partial throttle than at full throttle as well (too rich I'm guessing).
The rough idle bugs me a bit, but changing the FMU "setting" won't help that.
Does anyone know what I should be running for fuel pressure at idle, cruise and under boost? (I'll need that data soon.)
Well, the good news is the car is running rich rather than lean!
Rich, right?
