- 92 & 16 Meyatas
Happy Thanksgiving everyone!
Same to you Chris and Amanda! And all the nemoc peeps where ever you are now!
Bruce, are you anywhere near Corry Station? I spent a year and a half there training.
Had a great thanksgiving! We're all down in NC on lake Norman. Going to do some boating tomorrow!
The intake kit I was looking at for the REPU is out of stock, and not sure if it will work with my block anyway. Lui is talking about getting everything separately and having his buddy fabricate the manifold. I'm leaving him to figure it out as I don't know how to talk the talk with this stuff and the vendors are hard to get in touch with. Essentially the plan is to install a quad throttle body, one for each intake port to maximize torque. It's a bit different than the typical dual weber style you typically see. RX8 fuel injectors. AEM smart coils (no need for ignition box, they are wired straight to ECU). Electronic crank sensor replaces the distributer. Basically completely modern ignition and fuel system all controlled by the Adaptronic ECU. Wideband, throttle position sensor, temps, all plug and play into the adaptronic harness.
We're also thinking about getting a chassis wiring harness kit. I talked about upgrading the fuse box and that lead to a number of things that need to be done We'll control an electric fan from the ECU and there are a number of other circuits that we need. Doesn't make sense to piggy back things on old fault prone wiring. There are so few electronics and we're going to do a wire tuck anyway that it just makes sense to rewire everything down to the turn signals. It will make integration with the Adaptronic easier too.
We did some quick measurements and it looks like an RX8 transmission will drop in. I would have to get an electronic to analog speedometer converter if I wanted to keep the factory gauge. That will likely be phase 2 though, when we pull the motor to port it, it will go back in with a new transmission, flywheel, clutch, etc.
So yeah, haven't ordered any parts yet...but I'm getting excited. I was out driving the other day and the carb doesn't like the cold. It starts up fine with the choke and all, but on the highway it stalls intermittently. I don't drive it much in the winter but since we haven't had any snow I'm still trying to take it out once a week. Lui expects to see us go from 115hp to about 150hp with the ignition and fuel upgrades. Not sure if I shared the dyno sheet here but it is super lean right now so just a little more fuel can go a long way. Then when we do the porting, 200hp to the wheels at 10k rpm might be possible. I think that's a little wishful thinking...but if we get anywhere close to that I'm going to drop the suspension back down and put some performance rubber on it.
Other research projects....
A REPU showed up on BringATrailer a few weeks ago. Sold for $13k. It was nice, but not nearly as nice as mine. It had Miata seats in the cab. It's got me thinking about doing something similar...but with the white/orange exterior I don't think a black interior would work. Too bad there wasn't a white interior option for the NA miata. That truck also had a steering box from an '84 B2000. It supposedly has a slightly faster ratio...and less play. So, that's another upgrade in the back of my head...not hard to find one of those steering boxes and it's probably an afternoon job.
Crickets [emoji17]
Closest OEM you can get is the light beige, but that wouldn't look right.
FWIW, you could also get a pair of miata seats and get them custom reupholstered. The Katzkin kits are reasonably priced and work pretty well. There are plenty of stock miata seats that are cheap and would fit the bill.
I thought about that. Forgot about Katzkin though. I'd want the ones with the speakers...and I'd wire them upAnyone seen the "pearl" color? Is it pretty much white? I think I'd have to redo the door panels to match.
