So installing that B&M shifter was a b****. One of the rings on the outside of the blue bushing collar was a little loose (and must've expanded with grease or something), so it was slipping off and bunching up (and not going into the cup). I had to use an xacto knife to push it back done into the groove and eventually had to lay my entire weight into the shifter to get it to seat. And the retaining ring was tough to work with, I had s*** autozone/OEM brand pliers that would start to bend when the ring was fully compressed.
Also, 3rd shifter linkage bushing install didn't go smoothly either. Then misplaced the shifter connection bolt (or the shop I brought the 3rd linkage to get the rivet air-hammered out lost the bolt). So another day's delay.
