I’m looking to keep this vehicle for a while so dropping in size is for cost efficiency and ride quality. I’d be selling my 19’s. I’m not sure how I feel about the stock 17” wheels for a machine gray vehicle. Doesn’t give the car much contrast.Your stock wheels are 18x7 and have a 5x114.3 lug pattern with a +45 offset. Stock CX-5 17s are the same everything but 17 instead of 18.
EDIT: Wait, you got 19s? They are 7.5. wide, but again, same everything else as far as I know.
What do you want to do? wider? taller? offroad? VIP? hella frush?
It's really up to you.
The stock wheel size for CX-5 should be either 17X6.5” or 19X7”.Your stock wheels are 18x7 and have a 5x114.3 lug pattern with a +45 offset. Stock CX-5 17s are the same everything but 17 instead of 18.
Yeah, 2018 is the only model year on Touring comes with 19” wheels instead of 17”’s.EDIT: Wait, you got 19s? They are 7.5. wide, but again, same everything else as far as I know.
In theory for 18” tire, 225/60R18 with 28.6” overall diameter is the most compatible size to stock 225/55R19 with 28.7” overall diameter. You’d need 18X6.5 wheels.I’m looking to keep this vehicle for a while so dropping in size is for cost efficiency and ride quality. I’d be selling my 19’s. I’m not sure how I feel about the stock 17” wheels for a machine gray vehicle. Doesn’t give the car much contrast.
Thank you. That’s super solid adviceIn theory for 18” tire, 225/60R18 with 28.6” overall diameter is the most compatible size to stock 225/55R19 with 28.7” overall diameter. You’d need 18X6.5 wheels.
Honestly you’d only save less than $100 each time you need a new set of 18” tires, and nowadays it’s once in 50K ~ 70K-mile business. With money you invested on a new set of 18” wheels, you really don’t save too much money, as the selections on 225/55R19 tires are getting much wider.
You won’t get much better ride with 18” tires than 19” tires either. 17” tires? may be. You can always get softer 19” tires for better ride. Check the Ratings Charts & Reviews on Ride Quality under Comfort Performance in Tire Rack website for tires with better ride quality.
Of course if you want a new set of 18” wheels for cosmetic reason, more power to you.
Sorry if I was wrong, I was looking at this.The stock wheel size for CX-5 should be either 17X6.5” or 19X7”.
My man! Thanks for the infowhy would he need 18x6.5 wheels? That's likely an OEM-only wheel size. 18" aftermarket wheels have a very limited selection in 7" width, less limited in 7.5", and a HUGE selection in 8" width. If you look up 18x6.5 wheels on eBay, you'll find pretty much only OEM wheels, with several being compact spares for cars with larger wheels.
I can't even begin to say what would fit and what won't, just telling you what's out there. I was just going by the big wheel distributor websites like Fitment Industries and Discounted Wheel Warehouse. They both have zero available in 18x6.5, but thousands available in 18x8.My man! Thanks for the info
Yeah I’d go with whatever they recommend. They know better than I doI can't even begin to say what would fit and what won't, just telling you what's out there. I was just going by the big wheel distributor websites like Fitment Industries and Discounted Wheel Warehouse. They both have zero available in 18x6.5, but thousands available in 18x8.
I would not blindly go by what they recommend....I would also do your own calculations to verify....using on line calculatorsYeah I’d go with whatever they recommend. They know better than I do
I’ll do my own research then to make sure. You’ve been a big help. I appreciate all the advice and input. Good lookin out manI would not blindly go by what they recommend....I would also do your own calculations to verify....using on line calculators
This particular site has been upgraded to select equivalent sizes., such as the afore mentioned 225/55-19 is most similar to 225.60-18. You want to keep within 0-1.5% of the OEM tire diameter, because that is what the vehicle speed sensors assume. This site recommends 1% in general.
I would cross check with other sites such as tire rack to see that there are a selection of sizes actually available on the market, and to see what average prices are.
Things have changed now, but I had a AWD Acura sedan with 18 inch equivalent (they were metric sized) wheels, and I upsized 1 inch to 19, trying to do a conservative +1 upgrade while keeping the weight down (pretty easy because the OEMs were Michelin PAX tires and wheels). It turned out that the tire sizes in 18 and 20 were less money, and there was more choice available, than 19 inch tires, but that was over10 years ago,.. However, the lesson was not lost on me...I always check for that too.
I said “in theory”, 225/60R18 tire has similar overall diameter as stock 225/55R19 tire and recommended by Tire Rack for 18” tire. And the measuring rim width for 225/60R18 is 6.5”. This means every car manufacture will use 18X6.5 wheel for 225/60R18 tire from factory.why would he need 18x6.5 wheels? That's likely an OEM-only wheel size. 18" aftermarket wheels have a very limited selection in 7" width, less limited in 7.5", and a HUGE selection in 8" width. If you look up 18x6.5 wheels on eBay, you'll find pretty much only OEM wheels, with several being compact spares for cars with larger wheels.
but I thought OP was asking about aftermarket wheels. 18x7 is going to be the narrowest 18" aftermarket wheel available. 225/60-18 is rated for mounting on 6.0 thru 8.0 inch rim widths. I would look for a 18x7.5 or 18x8 for that particular tire size, since there's a large wheel selection available in those sizes. Or go to a wider tire if desired as @surftoad mentioned.I said “in theory”, 225/60R18 tire has similar overall diameter as stock 225/55R19 tire and recommended by Tire Rack for 18” tire. And the measuring rim width for 225/60R18 is 6.5”. This means every car manufacture will use 18X6.5 wheel for 225/60R18 tire from factory.
Of course OP can use whatever tires and wheels he prefer. But this tire / wheel combination will be used by car manufactures.
I went the OE+ route and bought some take off cx 30 18 x 7.5 rims and installed 235/60/18s on my 20' machine grey AWD CX5. they're about .4" larger in diameter then the 19 equivalent but remain within the 3% deviation limit. Next step is plasti-dip the wheels flat blackI have a machine gray 2018 CX-5 touring. I wanna downsize my wheels to 17” or 18” but I need some ideas for which ones to buy. I’ve been on tirerack for a few days. lol
People can ignore “measuring rim width” when they’re looking for alternative tires and wheels with optional sizes. But car manufactures will follow “measuring rim width” matching tires and wheels. For optional sized 225/60R18 tire for CX-5, the measuring rim width is 6.5”. You could use any rim width within 6” ~ 8”, but 6.5” is the “designed width” for 225/60R18 tires. Wider wheels should get wider tires for the best performance. But suspension rubbing can be an issue. Both of my front struts have rubbing black marks even from stock 225/55R19 Toyo A23 tres.but I thought OP was asking about aftermarket wheels. 18x7 is going to be the narrowest 18" aftermarket wheel available. 225/60-18 is rated for mounting on 6.0 thru 8.0 inch rim widths. I would look for a 18x7.5 or 18x8 for that particular tire size, since there's a large wheel selection available in those sizes. Or go to a wider tire if desired as @surftoad mentioned.
