My wheel FELL OFF - BC coilover failure
i've emailed the head of sales at BC a link to this thread, i'd like to see if they chime in at all
On Aug 13 I went out for some photos and made this thread http://www.mazdas247.com/forum/showthread.php?t=123751456 and on the way home I hit an uneven surface. There was a clunking noise coming from the RF strut. I pulled over and saw oil dripping from the bottom of the strut. The strut had blown. I had installed the coilovers about 11 months previous.
Here are pics of the hardware itself. You can see the threads and how they were "cleaned off" when the strut flexed/collapsed.
So it appears the strut cracked at the seam when you hit an "uneven surface," then completely separated after continued use. Sounds like an incredible combination of unfortunate events.
Your first indication that something REALLY serious went wrong was that the leak occured at the bottom of the housing - not at the top where the piston meets the tube. In any case, glad you're ok. Good luck getting everything fixed.
Nah, Edwin is still theMAN....no coilovers for this application, which is what this thread is talking about!
If he meant to write "eibach don't make coilovers for the ms3!" then you would be correct, but to me it looks like he said " eibach don't make coilovers!" in which he would be incorrect. Which is fine even the most knowledgeable people make mistakes every now and then.
Pete from BC racing has read the thread and has said he'd be looking more into this in the morning for me.
The crack which resulted in the physical failure of the strut is not what made it leak. The portion of the strut where it separated is not a sealed portion containing oil, it was just for structure. The actually dampening portion of the strut starts about 4 inches above where the break occured.
this is incredible. im really concerned now about mine, because mine are always on full stiff pretty much
Haha me too. I went out to my car and softened up the fronts as soon as I saw this thread. Couldn't get the backs cause the way they sit in the car but I'm not as worried about them since they aren't put under quite as much stress.
been talking to the head of BC North America. he is very interested in talking to the OP about this.
Yes, the coilover is 2 separate pieces. But where you pointed the arrow wasn't where you broke it looking at the picture in the OP. That is some freakish s*** that happened to you.
I removed that post/pic with the arrow since it wasn't accurate and since there are picture with the real damage available now
i believe they have recommended settings for dampening on the street opposed to the track
even tein..etc doesnt recommend running full stiffness on the street.
i've passed along lister's info to the head of BC in an effort to resolve this for everyone involved.
