same dam thing happen too me but with the driver side
wow really. ive never heard of this happening to anyone else. how did your situation play out? warranty? other damage to car?
(shocked)
I have indicated here in this pic where the break was. Again it looks like the strut was built as 2 separate pieces and threaded/welded together at this connection point
I know the pic shown is not the coilover for the MS3 but they have a similar design
Of course they're 2 piece. How else would the ride height be adjusted?
Your failure sucks, no doubt about it. Of course running them full stiff when BC specifically advises not to on the street probably had something to do with this.
I would really like to see pictures of this piece. If they were properly installed and adjusted there is no way for the strut to fall like that. The lockring would keep the upper half from collapsing into the lower body.
The only way I can even imagine this happening is for the T tab not being properly aligned into the wishbone. You said it was broken off right?
that is a good question and i shouldve included that in the original post
i was all the way stiff in the front (32/32 i guess) and about 18/32 in the rear
i know having it all the way stiff most likely contributed to it blowing
correct my friend, you were running them way too stiff. also, your car could have handled and ridden wayy better and you would have really enjoyed the BC's if they werent so damn stiff. Sorry to hear your s*** failed though, live and learn kinda s*** i guess?
Running full stiff on a daily driving schedule and not at a smooth track probably didn't help much. But, if BC warranties them using any setting at any road surface, you are OK. Try the next set at 1/2 way.
The BCs are great on Neon SRT4-s. I have an MS3 and an SRT-4. Both great cars.
Yeah but track stresses would be much greater than on the street. Also not every track is smooth really. But if its not okay to run them at full stiffness on the street then it shouldn't be sold on a street coilover set up. Not bashing on BC because we haven't heard what they have said about it yet. Just saying that running full stiffness should not what is at fault here... yeah it probably wasn't comfortable to drive but shouldn't cause it to break in two.
If the BC's weren't designed to run at full stiff for any period of time then why include it in the range of adjustment in the first place? TBH, running them full stiff in a track setting would probably be more stressful than anywhere else.
Well I was just saying that from an engineering stand point that it should be designed to hold max stiffness for 24/7 on or off the track.
Not trying to bash BC
Yes, the coilover is 2 separate pieces. But where you pointed the arrow wasn't where you broke it looking at the picture in the OP. That is some freakish s*** that happened to you.I have indicated here in this pic where the break was. Again it looks like the strut was built as 2 separate pieces and threaded/welded together at this connection point
eibach don't make coilovers! I was talking about coilovers since this thread is talking about it!Oh...and Edwin, I'm glad you didn't mention Eibach...I had both of my front
springs break on me within the last two years.
exactly, it broke at the BOTTOM where it fits into the spindleYes, the coilover is 2 separate pieces. But where you pointed the arrow wasn't where you broke it looking at the picture in the OP. That is some freakish s*** that happened to you.
