where to start with today. With the mishap yesterday, today we were just going to do some things that didn't involve the engine: assemble turbo, run wires.
Using the GT28R, we had to rotate the cold side, which meant making a custom bracket for the wastegate acutator. Kevin was awesome at that.
So we went ahead and attached the turbo to the manifold, and realized the oil drain fitting wouldn't allow for the line to fit. Luckily I aslo had a 45* fitting, so that went in.
After that, we decided to hang the turbo/manifold from the studs. That's when we ran into the big problem.
The wastegate actuator hits the block. We can't make it longer because it'll run into the clutch actuator assembly. The only idea we came up with is to get another actuator, cut the shaft short, and mount the actuator between the turbine housing. The other option is to send the turbo back, and exchange it for at GT25R (MSP turbo).
One thing that did get done was I got the AEM wideband mounted. I had to sand the inside of the holder to get the gauge to slide in.
