E55 projectors are bi-xenons and have probably THE BEST high beam output
whose your "seller"? If the E55's you're lookin at aren't bixenons, they are not E55's
As to the lack of high beam, you're going to want a high beam!! The projector cutoff does NOT throw light down the road like a high beam does.
as to a dual projector setup inside an ES housing, i dunno. I'd suggest getting a pro5 set of lights as spares to build that route.
Then you could get a halogen H7 high beam projector
and honestly, i suggset signing up to HIDplanet . com just remove spaces
research research research before you start buying parts for your retro! Otherwise, if you get inferior parts (not legit e55's) you could finsih your beautiful new lights and the light output be WORSE than your stock halogen setup
