My boot install
Critter
2001 Astina SP20
Well, it's almost finished.....but this gives a good idea of how it will look.
Things are just put there for this pic, the sides will have hinges and the whole thing hinges and comes out so I can still get at the spare, with some mucking around, if I need to.
Subs are Pheonix Gold Ti12D's.
Fused distribution block also PG Ti series.
Amps are a JL 500/1 for the subs (on the right) and a JL 300/4 for the front stage (on the left).
There will be toggle switches that line up with the edges of the distro on the subs side of it, one for the 2 halogen lights in the sides, the other for a remote switch of the lights in the distro.
There will also be a flying M badge between the subs, high-ish :)
FYI...front stage is Morel Hybrid. Soon I am doing fibreglass kicks with a 4" and tweeter fed by 2 channels of the amp off passive xover. 6.5" drivers in the doors off the other 2 channels, "semi-active"......
Spare is in the normal place.
It's covered in 4mm dark grey carpet to match the boot trim near as possible.
Each side has the halogen lights if that is what you are talking about ELEmental
