MS6 - evo X wheels
Where does it exactly rub in the front? You should try putting that blue masking tap around the fenders to see where you rub.
rubs at the tabs where the plastic fender well holds on to the fender itself. its eating through most the plastic.. i'll probaby roll it up a little to make some room
on H&R springs... i can either get new tires with lower profile or stiffen the front with koni's .. either way.. neither is rational to do.. for now i'll drive carefully in the turns and dips
I am also on the h&rs with the evo wheels, I think the other guy with evo wheels also has the same springs. Its such a great combo.
If you went with 225/40's, the tires will stretch and the tires will be a little small in diameter. I wouldn't think you would have a problem rubbing.
hey so whats the bore size on the evo x wheels?! im aobut to pick some up tomorrow! will they fit my 2003 mazda6s @ 67.1mm bore?!
I bought my evo wheels 2 hours after i posted that last post about the bore size...I am looking at wrapping them in 235/40 has anyone mazda6 owners done this yet?!
no but it'll be fine with 235/40.. members have done 245/40 with these wheels specs .. you need a major roll and slight pull in the back
does it rub all the time.. or ONLY your cornering..?
if its only why cornering.. .. upgrade your sway to something thicker/stiffer should solve the issue...
had to do it.. to run stggrd wheels on my 3hatch..
