- 13 MX-5
Where does it exactly rub in the front? You should try putting that blue masking tap around the fenders to see where you rub.
learn to drift.
If you went with 225/40's, the tires will stretch and the tires will be a little small in diameter. I wouldn't think you would have a problem rubbing.on H&R springs... i can either get new tires with lower profile or stiffen the front with koni's .. either way.. neither is rational to do.. for now i'll drive carefully in the turns and dips
is that -2degrees?
