Mike's 2018 CX-9 Signature
So far, so good! Don't sweat the battery, its a consumable and batteries in general don't seem to last as long as they used to for whatever reason. At least we're not forced into using a more expensive AGM battery, I've had to replace the AGM battery on my dad's 2018 Equinox twice already. For the cost of those two batteries, I could have bought a brand new battery for my CX-9 every winter since I got it! lol
I bought a battery for my wife's Jetta sometime back. Car for totaled (by me 😔) but I was able to get the new Kirkland battery out before it was gone for good... It sat on my concrete garage floor for nearly three years before I decided to hook it up to my 04' Eclipse GTS, now that I fixed the clutch and a handful of other issues.
I had to buy new terminals etc as the Jettas need a battery with the positive terminal on the left side.
Anyways, the thing turned over on the first try with no hesitation. The engine needed to be revved a bit as the gas needed to circulate end all the components back back to life, but needless to say, I was impressed with the battery.
Kirkland for the win.
Swapped in a new battery in the Costco parking lot the other day. Figured I'd take advantage of the nearly empty Return/Warranty line. Original battery was purchased 2 years ago, for $120 CDN. New battery was $150 CDN, but because of the warranty, they refunded the cost of a brand new battery to my debit card, and I just had to buy a new one, effectively resetting the warranty clock to 48 months (y)
Before the Kirkland stuff, I used to fill with Pennzoil Ultra Platinum or Castrol Edge, and both were $35-38 per 5L jug when they were on sale.
When I did my oil change a couple of months ago, I got a pack of 3 PUP from Amazon. $27 per jug.
Also I just wanted to say I like the way you take care of this car. I'm sure it inspires others to do better.
Thank you! I do what I can, when I can. (y)
Forgot to post when I topped up with OEM coolant on March 4, 2024. Filled from just above the low mark to slightly above the full mark.
Also did an oil change on March 29, 2024. Almost 109k kms on the odometer.
Nearing 113k kms. Changed out my two front wheel hub and bearing assemblies (thanks potholes). I just used economy brand GSP parts this time. It's much quieter now. I attached a vid to show how much play the old bearings had on the worst side. o_O
I also picked up more OEM ATF for another drain and fill. Will be doing this at the same time as I do a drain and fill of the front and rear diff fluid in the next week or two.
Front brake pads are finally starting to near their end of life. I'll probably change them out next summer as they still have about 4-5mm of material left.
I went to a local dealership yesterday so they could do a damage estimate for my insurance. This is in regard to this collision from a couple of weeks ago. Turns out that both of the damaged doors need to be replaced entirely, because they were hit hard enough to damage both the outer and inner shell. Dealer told me doors are backordered with no ETA, which according him, means that there is no stock available in North America, and they will have to be shipped from Japan.
Oops, forgot to attach the video to the previous post.
I didn't think it was going to have this much play.
  • 20240522_174428.mp4
    15.5 MB
Oh man. The vibrations!
I hope the parts availability has recovered from COVID days. I had to wait 8 months for my cylinder head on my 18 CX5.
Sweet Jesus! Or are you Thor level strong!?
That'll definitely cause vibrations, excess tire wear, early suspension failure etc etc etc.
Was it a pain getting out?
Wow!
How was it changing hub assembly? I've never done it on a "new" vehicle before.. Usually a 10+ year rusty junker where it's welded itself on! Probably not a bad idea to change wheel bearing/hub assemblies on a schedule anyway, I bet a lot of people drive on them noisy without even realizing.
Wow!
Usually I take my car to my uncle for repairs I don't feel comfortable doing myself. He used to be a Nissan dealership mechanic but now just does jobs on the side as a "shade-tree mechanic", and lets me hover around and ask questions so that I can learn. Quite honestly the part that took the longest was removing the ABS sensor without damaging it. The 10mm bolt holding the sensor in place came out fairly easy with some PB Blaster, but the sensor itself didn't want to budge, so we had to work on it for a while with some small picks, screwdrivers, and ATF.
He's got all the right tools for the job so the rest of the process was pretty straightforward. Didn't need to use a torch or anything despite the rust. There was an intermittent squeal/scraping noise when I drove it home, but after talking with him on the phone it just turned out to be the brake shield the needed to be bent back a little bit.
I've had wheel bearings last 300k kms or 10+ years with no issues on other cars. My wife's Civic is 18 years old now and its still on the original wheel bearings. The difference in this case, though, was the sheer number of really bad potholes we've had to deal with in the city over the last few years. Despite being as vigilant as I could, I still hit a few potholes (mostly on the passenger side), a couple of them were hard enough to cause minor bends in the rims. Then I hit one that caused significant bends and the wheel vibration, so I guess the bearings finally gave up. Of course, it doesn't help that I also have wide wheels with a more aggressive fitment and lowering springs. It is what it is.
Oof, yeah, if you bent a rim, then it's likely a coin flip whether the bearings will be next.
Maybe a blessing in disguise though, changing them before they're a real pain! Good to know about the ABS sensors, they can be a real pain. Wonder if there's any way to prevent that from happening.
Did another drain and fill of the ATF yesterday. I'd post pics but it was basically the exact same process as the last time, with the same result. I did manage to break one of the underbody tray bolts due to rust and corrosion, but there are plenty of other bolts and fasteners holding the underbody tray in place, lol. It's been about 11k kms since the first drain and fill, almost 1 year ago on the day.
Current odometer reading is 113521 kms.
Not trying to re-read all 214 posts, have you done dropping the pan to change the filter cartridge before?
I was amazed that the tray bolt would rust and break like that? Never experienced such problem in Texas.
Nope, have not dropped the pan. I don't think I will, might just stick with drain and fills every 50k kms.
Rust and corrosion can be a problem here, we salt the roads quite a bit in the winter. In hindsight I probably should have used some penetrating oil first.
I believe this’s the minimum maintenance for ATF change, which may be good enough for a long time. This’s what I’ve been doing on my 1998 Honda CR-V with 193K miles, ATF drain&fill once for every 60K miles (manual says 75K miles).
Yeah I hope so!
On the other hand, my wife's 2006 Honda Civic has never had a transmission fluid or filter service, and her car has the equivalent of over 200k miles on it. That fluid is staying put, haha. I'm surprised it's lasted this long with the way my wife used to drive it.
Yeah I hope so!
That's civic for ya... Thing just won't quit.
