Sir. SpeedALot
- Mazda 6s Lapis Blue / Mazda3 5-door Sunlight Sliver
MazdaUSA's Reponse to Brake Issues
I contacted Mazda about the grooves showing up on my rear rotors and this was their reponse.
Dear Eric,
Thank you again for contacting Mazda North American Operations. I
appreciate the opportunity to respond to you.
In regard to your inquiry, the brake dust on the rear wheels is due to
the type of brake pads used, and the grooves on the rear rotors is due
to the coating on the rear rotors. If this occurs, the dealership will
either machine rotors or replace them if necessary. Unfortunately,
there is no other avenue for you to take this. Your comments have been
documented for our corporate records.
I certainly apologize for any inconvenience this may cause you.
Has anyone tried upgrading the brake pads? Is this a DIY kinda job or do they need to be installed by a mechanic?
Dear Eric,
