HI All,
I own a 2009 mazda 2 and since few months back it began to vibrate excessively when I start it for the first time of the day.
In the cold start
It vibrates quite a bit & I can feel the vibration in steering wheel. (I know its usual to increase rpm until engine come to proper temperature hence bit of a vibration, but this is more than usual)
Engine is quite loud until engine come to proper temperature
then when I put it in to D or R this vibration is reduced. but In R vibration is more than while in D
until I drive for 5-10 minutes I feel the vibration in steering and also feels some sort of mechanical grinding. (I dont here any grinding sound but I feel grinding vibration)
after 5-10 minutes of driving (when engine is become hot) everything comes back to normal.
and will run fine as long as engine is hot.
if it cools down again, this issue occurs again.
Any ideas on whats happening?
I did some search on internet and came across 2 possible scenarios
I'm not sure how bad engine mount can cause this
I would like your opinion before going to a repair shop, so I will know whats going on and repair shop wont rob me (shady)
Thanks
P.S.
following video shows how my car engine move when shifting through gears. perhaps you can conclude it is a bad mount through this ?
In the cold start
- bad engine mounts
- crack in exhaust manifold (in cold start some leak through crack and as its getting hotter , crack seal it self closing the leak hence vibration goes away
Thanks
P.S.
