DIY Mazda Firmware Update Information
Just updated my 2018 Mazda CX-5 from 59.00.504 NAN to NA 74.00.324A! Thank you @Candurin for the file and your help.
Because I have OCD tendencies, I needed written step-by-step instructions to do the update. Found YT video by @randomtorontomans which included a link to his Google Drive File containing written firmware update procedures, and checksum utility: YouTube
Very helpful.
PLEASE READ THE POST IN ITS ENTIRETY BEFORE POSTING A REPLY IN THIS THREAD.
To gain access to these files, please DM @Candurin. We ask that you be respectful when you do so. Candurin is a fellow user, and should be addressed as such. They are not a bot. Further, be mindful of your expectations - they may take some time to reply to your message for any number of reasons. Please be patient while you wait for a response. Failure to abide by these requests will result in corrective action, up to and including a permanent ban. Again, be respectful.
NOTE: If you have installed anything like AIO Tweaks, you must uninstall it before proceeding any further with firmware updates. The firmware update will not work with AIO Tweaks installed.
Firmware versions are region specific, so when you send a DM to @Candurin for the links, be sure to specify the following:
IMPORTANT NOTE: These files and processes are compiled from third party sources. Please be aware of the risks of performing these updates yourself. There is some potential to brick your CMU if some steps are missed or the wrong files are used. Mazdas247 does not assume responsibility of the actions taken by its members or the damages that may result from those actions.
These files are being provided as a courtesy to our members, by our own community members, to allow others to avoid the potential dealer fees and time wasted in the dealership, waiting for a technician to perform these updates. Keep in mind that these files and the links that may be provided to you carry no guarantee that they will remain intact in the future.
Typically, most people will perform these firmware updates in conjunction with an Android Auto Apple CarPlay retrofit kit, which can be purchased or ordered from any Mazda dealer. However, these firmware updates may also resolve certain bugs and glitches in previous versions, and may also improve overall performance of the infotainment system.
The most recent, and final update at this time is
. This firmware version/format (.up) will not be installed on new Mazdas. You must use the correct region for your Mazda, as detailed below.
74.00.324A NA N for North America, USA, Canada, Mexico, etc.
74.00.324A EU N for Europe and UK, etc.
74.00.324A 4A N (ADR) for Australia, NZ, Middle East, Thailand, South Africa, Oceania, etc.
APPLICABLE MODEL(S):
2014-2018 Mazda3
2016-2021 Mazda2
2016-2021 Mazda6
2016-2021 CX-3
2016-2021 CX-5
2016-2021 CX-9
2016-2021 MX-5
***UPDATE as of Oct. 2nd, 2024***
The following versions are also available for the '21-'24 models listed below.
7000C0A-NA11_10010 (2024 CX-90)
7000C0A-NA05_11022 (2023 CX-50)
7000C0A-NA10_10004 (2023 MX-30)
7000C0A-NA02_11046 (2022 MX-30)
7230C1A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - USA)
7230C5B-NA03_10022 (2024 CX-30/Mazda3 w/ out NAV - USA)
7230C2A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7230C6B-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7000C0A-NA06_12018 (2021-2023 CX-30/Mazda3)
7000C0A-NA12_10016 (2024 CX-5)
7000C0A-NA03_11048 (2021-2023 CX-5/CX-9)
7000C0A-NA01_12006 (2021-2023 CX-30/Mazda3 Non-Turbo)
7000C0A-NA04_12006 (2021-2023 CX-30/Mazda3 w/ Turbo)
Once again, to gain access to these files, please DM @Candurin.
Do not post in this thread asking for the links or files. your post may be missed. Keeping track of DMs is much easier. Again, be respectful when requesting update files, and be patient while waiting for a response.
Note that firmware versions are region specific, so when you send a DM to @Candurin for the links, be sure to specify the following:
I have 2019 CX5 Signature.
Just uploaded 74.00.324A No issues
Region is NA Canada
Now want to upload update to Gracenote.
Format fresh USB key. Same one I used to load update to firmware. Download and load Gracenote_ADR_January2022.up. Also tried Gracenote 1.1.1.03399_NA.mcg
Car recognizes the USB key.
I select Update under Setting/System.
Does not recognize the file.
What am I doing wrong?? Thanks
It’s because you’re using an incompatible version of gracenotes. The one you’re trying to use is for the newer gen Mazdas. Your gracenote version was updated to the latest version when you updated the firmware to 74.00.324 (which includes an update to gracenotes version 00.12.003).
Additionally, anything ADR is not for North American region.
I now understand that ADR was wrong. So there is no further update to the NA version (Gracenote_NA_January2022.up)? That was already included in the update to 74. firmware?? Thanks so much
The most recent, and final update at this time is 74.00.324A. This firmware version/format (.up) will not be installed on new Mazdas. You must use the correct region for your Mazda, as detailed below.
2014-2018 Mazda3
2016-2021 Mazda2
2016-2021 Mazda6
2016-2021 CX-3
2016-2021 CX-5
2016-2021 CX-9
2016-2021 MX-5
7230C1A-NA03_10022 (2024 CX-30/Mazda3 с навигацией - США)
7230C5B-NA03_10022 (2024 CX-30/Mazda3 без навигации - США)
7230C2A-NA03_10022 (2024 CX-30/Mazda3 с навигацией - Мексика)
7230C6B-NA03_10022 (2024 CX-30/Mazda3 с навигацией - Мексика)
7000C0A-NA01_12006 (2021-2023 CX-30/Mazda3 без турбонаддува)
7000C0A-NA04_12006 (2021-2023 CX-30/Mazda3 с турбонаддувом)
Ещё раз, чтобы получить доступ к этим файлам, пожалуйста, напишите в личные сообщения @Candurin.
Не пишите в этой теме с просьбой предоставить ссылки или файлы. Ваше сообщение может быть пропущено. Отслеживать личные сообщения гораздо проще. Ещё раз, будьте уважительны, запрашивая файлы обновления, и будьте терпеливы, ожидая ответа.
Обратите внимание, что версии прошивки зависят от региона , поэтому, когда вы отправляете личное сообщение @Candurin с просьбой предоставить ссылки, обязательно укажите следующее:
У меня установлена версия CMU_7000C0A-EU08_10024 есть проблемы с андроид авто, ищу обновление CMU_7000C0A-EU08_10030.kwi
Thanks. Figured it out. I was trying to load the ADR version rather NA. All good. Turns out I didn't have to update the Gracenote because it was done when I did the update from 70 to 74. Otherwise, great car.
this is what Google Translate gave:
I have version CMU_7000C0A-EU08_10024 installed and I have problems with Android Auto. I'm looking for the update CMU_7000C0A-EU08_10030.kwi.
Successfully updated 2015 CX5 from 59.00.100 - Android Auto is working.
Expect the progress bar to get stuck at a % for a while - DON'T panic and restart.
Had to force my phone to allow file transfer mode to be detected / enable AA.
Thanks for supplying the AU files @Candurin !
Updated my 2015 3i from 55.00.750A (oddly, I found no references to this specific version anywhere) to 70.00.100 today - a big thank you to @Candurin for supplying the files and for verifying this particular upgrade path!
I followed the "New MARCH 2020 MAZDA Connect CMU Software Update Procedure" (the one with the red, blue and green text) PDF guide to the letter. I noticed that depending on the document, CMU sleep mode can be either 3 or 6 minutes. I gave it 6 minutes both times to be safe.
Worked like a charm and completed in just under a half hour. Going to let it burn in a bit before jumping to 74.x
QUESTION - does anyone know if Mazda P/N C922-V6-605A (the cables for the updated hub) are long enough to reach from the head unit to the armrest center console? Nearly all videos and installation documentation I've found show the hub in front of the shifter and below the HVAC controls.
Does anyone know if you can change region by updating the OS? I have a Japanese car but would like to update to AU/NZ version of the OS.
Can I overwrite / install the different region.
Current is:
70.00.110 JP M
Did you get help I’m facing the same problem
Yes. You can change region by simply updating to your local region’s firmware.
Please note this applies to the pre-2021 (6th generation) model years only.
Thanks to @Candurin , update went perfectly smoothly. Now to see about getting that hardware upgrade...
When I called the dealership about this, they mentioned they had a power supply they hooked directly up to the CMU etc. I imagine that's the reason for the "please re-start" message, must be lot more coherent when it refers to a switch that you just need to flip off and on.
