Hi everyone,
I’m looking for help diagnosing a very strange electrical / CAN bus issue on my 2011 Mazda CX-9
This feels like a power/ground integrity issue affecting the powertrain CAN bus, If anyone has had a similar issue or experience with this, I’d really appreciate any guidance. Thanks a lot!
Symptoms (progression over time):
- While driving, AT and CEL lights come on, and the transmission enters fail-safe mode (stuck in 3rd gear).
- If I stop and restart the car, everything returns to normal.
- An OBD scan shows U0073 (CAN communication bus off).
- Sometimes, TCS / traction control lights also begin to appear (sometimes before AT/CEL).
- This stage happened 2–3 times over about 2 months and did not seem very serious at first, so I initially thought it was an occasional issue.
Eventually the problem becomes much more severe:
- Dashboard lights flicker in on/start, involving almost all warning lights. (looks exactly same as this video: link)
- Turn signals and hazard lights have no clicking sound at all.
- Gauges (RPM, coolant temperature) jump from 0 to actual values.
- OBD can no longer communicate with the vehicle.
- In most occurrences, there is no crank and no relay click
(ACC works, horn works). - After sitting for a long time, the car may start again.
- If forced to drive, engine RPM fluctuates abnormally, and the transmission remains locked in 3rd gear.
What I’ve already done / checked:
- Replaced battery
- Replaced ignition switch
- Checked starter / IG / engine relays and fuses (swapped for testing)
- Charging system seems normal:
- Engine off: 12.2–12.4V
- Engine running (when it does start): ~14.3V
- Battery negative to chassis ground tested OK
