gelo
2020 CX-5 GT (Premium) Machine Gray Metallic
Hi, I had my 2020 GT's rear brake rotors replaced around a month ago. Ever since they were replaced, the steering wheel no longer felt "firm" as it did beforehand. However, I decided to keep it like that because admittedly at the beginning, I kind of liked it. However, after doing a long drive thru the highway, I felt terrified that at any time, one tiny wrong movement would cause an accident. There is also a little bit of a steering wheel play, where while I'm driving (in the city, didn't wanna test in highway), I could move the steering wheel every so slightly on either direction without the vehicle moving out of the straight line. I could also move the steering wheel a tiny bit while the vehicle is off (shouldn't be the case, right?). The alignment also seems slightly off as it veers slightly to the right when I straighten the wheel and let go of it.
What could have caused this? I did not think getting the rear brake rotors replaced would change the way the car drives. When I first got this a few months back, it felt "connected" to me, where I knew where the vehicle was going in relation to how much I moved the steering wheel. I felt confident driving it and it felt sporty. Now, it feels "disconnected" from me, and I am trying to get used to the way it drives now due to how loose/light the steering wheel is.
Tire pressure is 35 psi, which is what's listed on the driver's side door. I did not change my wheels/tires before this problem occurred. I did have my lug nuts switched, but it's the same size as the one it came with (hex size: 3/4", 12mm-1.50, bulge acorn)? However, those were changed before I had the rear brakes done and did not notice a change with the way it drove at the time. So something was probably done wrong when they did the brakes, right?
