Threw all the wiring back in the car. I think I remembered where most of it went. The main goal of the weekend was to check the fitment of the new harness. Everything looks good inside the car. The hardest part is going to be figuring out where to put the Haltech fuse box. The engine side is a different story:
Things are a little long on this side (better than short). The biggest offenders are the speed sensor and crank angle sensor wires. They need to be shortened quite a bit. There's a little excess slack in the TPS, water temperature, oil temperature, and oil pressure wires but that's going to be taken car of by taking some length out at the firewall.
The biggest bummer of the weekend was the crank angle sensor itself. I'm still not sure if I got the wrong kit (would be the 2nd time) or if it's the wrong sensor but I can't physically bolt the sensor to the bracket. The sensor hits the wheel and the mounting holes are misaligned.
Some concessions were needed. The two ports on the oil filter adapter caused one of the sensors was out of reach of the wiring harness. I considered taking oil pressure at the stock location but that still stretched the harness more than I wanted. So I broke out the drill and tap and made a new port (nearest the oil filler neck) and plugged the one in the back:
Finally, I decided on a location for the coils. Ultimately, I kept them in the same place as before. The leads are long, but I already had them and I really couldn't come up with a better location. It's closer to the wheel and fender than the previous iteration so I could fit cold air ducting to the intake should I ever go that route. If I ever do come up with a better location in the future I can always move them as the coils have their own subharness that can be removed from the main engine harness.
The engine side of the harness goes back to LMS today to be modified. I also ordered (what I hope is the last) $200 in wiring products to finish the chassis side of things. I need to order some more aluminum sheet to finish off the radiator ducts and make some blanks for the side mirrors. Got the quote for body work in on Friday as well. Ouch...
