DO NOT REMOVE THE SECONDARY plates!!!igdrasil said:1. 18,572 miles (1500aprox turboed)
2. I dont have any oil pressure gauge nor restrictor, will take pics in a few minutes.
3. Yeah center housing was upside down when installed and ran like that about 20-30 miles. This was corrected, running perfect until 2 days ago. This is the only reason I see that could have damaged the seals.
Starting Today, this car will be stopped for the following 2 weeks until I solve all mayor issues, including clutch. Will take this time to install rear awr mount and remove those secondary intake plates....if the money reaches![]()
the VTCS plates yes, remove them but not the VICS.
well i forgot you had run it upside down. overheated and ruined the seals.
get the ones from spoolin and get boostin again. you will need to get an oil pressure gauge for future use to make sure everything is ok.
If you need help on the plate removal let me know and ill show you how i did it. or send it to me and we can fix it for you. maybe port and polish while its apart
