Keping Wastegate Open
Maxx Mazda
Contributor
Stock P5
Basically, for my new engine for the first 500Km's I don't want to boost at all. Just for a tank of gas. If I pull the spring right out of my TiAL 38mm, will the exhaust push it open so I don't boost at all?
why dont you just baby the pedal and accelerate slow? 1-3 psi of boost won't do any dmg. infact you want to boost a bit. just don't redline or go full throttle
I kept mine out of boost with the throttle pedal for the first 3000 km. Simple and effective.
You can drive the car out of boost. You should know around how hard you need to push to put load on the engine so that the turbo creates pressure. Just don't push so hard....I can go 90MPH without EVER hitting boost and go well above 3k RPM without hitting boost.
Ya I know that, I can do that no problem, but I want to put the engine under load but without hitting boost...
here's what you do. unhook the intercooler pipes. this is exactly how i'm running currently. no boost. the turbo spools..but in reality..nothing is happening.
Maxx Mazda said:
And suck in unfiltered air?
no no. just put a filter on. check mine.
lol @ NA cars with a turbo on them :D ;) I wish I had a built motor so I had to do that too
What pistons do you run with that? I'm on 8.5:1 and I'm thinking without bosot it's only gonan have like 90HP or something like that lol! I wont be able to merge!
you will be fine. just baby it under acceleration, and you will be ok. Thats exactly what i did, no problems at all. you will be able to keep up with traffic and drive normally!
craig
i have the same ones i believe. and don't fool yourself. w/ it open like htat. it still has power..promise(yupnope)
Be carefull if you take off the IC pipe, you could overspin the turbo.
