I have been having a bucking issue with my car. I thought it might be a vacuum leak, warped flywheeel, or a bad sensor. Well as I started to pull things apart to clean the MAF, I found that the intake tube downstream of the MAF that goes into the intake was cracked most the war around. Ah-ha! I found my issues!! So now what? I need a new tube. Should I go aftermarket or maybe just stick with stock. Where is a good place to get either? I will likely only have the car for another year, so I don't want to put a lot of money, but when things are broke, that's generally when I try to upgrade.
Looking to do something soon because my duct tape job will only last so long. Thanks!!
J.D.
J.D.
