Installed Morimoto Elite HID (non-xenon pkg)
@D_Frost--- did you ever get the XB35 bulbs to resolve your wire shadow problem? i want to order this kit and im unclear on which bulb i should be ordering. any input from others are welcome please~
Yes, the XB35 will fix the ground wire shadow issue. Being a bit picky, the cut off is not quite the same as when a regular Halogen bulb is installed (due to the position where the light is sparked/generated). You will want to adjust/aim the headlight after install to ensure optimal lighting.
There is a contradiction here. Up to a point is the H11 bulb that is needed for our cars and at the end is the XB35. Now which one is needed?
i installed the kit last week on my 2014 GT trim--- XB35 bulbs-- no shadows. 100x better then OEM halogens~
