Yes, the XB35 will fix the ground wire shadow issue. Being a bit picky, the cut off is not quite the same as when a regular Halogen bulb is installed (due to the position where the light is sparked/generated). You will want to adjust/aim the headlight after install to ensure optimal lighting.
