I have a line on a set of snows off a "03 eclipse or a 99 prelude" with steel wheels and the correct bolt pattern. How can I determine if these rims will work on my Mazda5 hubs? Do I need to worry about offset if the tire width is OK (205/55/16)?
Also, be sure the steel wheels are not HONDA OEM. Honda uses round seat lug nuts instead of standard acorn lug nuts. If the wheels are Honda, you will need their lug nuts too, or tragedy can occur.
